TPS question/ HELP
TPS question/ HELP
ok i keep breaken them and cant get it to idle right and if i do fing CEL comes on. went and go a volt meter and i have no clue what should read what voltage. need expert help kind of help cause im putten to much money into nothing.
RE: TPS question/ HELP
.97-.99 volts. It should be the middle and lower wires on the plug. Turn the ignition on, back probe the TPS and turn it until it read .97-.99 volts. This will eliminate the CEL light from coming on due to the TPS sensor being wrong. Idle issues may be coming from the TPS(if it dies) or the IAC. Once you get one problem fixed see if it still does it. It may take a bit for the car to relearn the idle.
ShaneB26154
35
03-04-2021 04:05 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
