Tire Question
RE: Tire Question
ORIGINAL: Derf00
245/40 is a SMALLER tire, not bigger...
There is about a 1/4-1/2 inch difference in overall diameter between the 245/45 and the 245/40 tire. 245/40has a wall height of110 mm while the 245/40 has a wall height of 98 mm. 25.4mm to an inch.
ORIGINAL: jmac72187
Your speedo will read 3.8% too slow. You won't notice much difference. Going with a bigger tire is similiar to going with a lower ratio gear, but that is too small of a difference to notice.
You just said that the same tire has different wall heights.
RE: Tire Question
ORIGINAL: jmac72187
RE: Tire Question
ORIGINAL: 1fstblckgt
No it wont.
ORIGINAL: POISND U
It's gonna look like ***...
No it wont.
Assuming he is stretching that accross a 18x9 wheel, it will. That's why I said I may have spoke too soon. 18x8 and he's fine.
RE: Tire Question
[quote]ORIGINAL: 97targa
Wrong! RPM's are measure by engine speed. You could put tractor tires on your car and it will read the same rpm's to get the specific hp and tq ratings on a dyno.
Not quite the answer to my question but I get the point
ORIGINAL: SnakeCarDriver
Speed is measured at tire RPM's??
09-08-2015 11:50 AM
