Dim Fog light
RE: Dim Fog light
It's unlikely to be a problem with the relay or relay socket, as there's just a single set of contacts for both lights. However loose or corroded wiring somewhere between the relay and the light isa likely cause.
RE: Dim Fog light
ORIGINAL: 6mustang6
id like to know this as well. my passenger side fog has always been dimmer then my drivers side. one night it looked alot brighter but now its dim again.
add me to that list. my passenger side fog light does the same thing. changed the bulb and its still dim..... ?
RE: Dim Fog light
ORIGINAL: E_LOW
ORIGINAL: 6mustang6
Check the plug for corrosion...
RE: Dim Fog light
Yeah, Its ticking me off. It must be a problem with a certain component somewhere if there are multiple issues of this happening. When i had it unplugged the pigtail looked fine. No corrosion or anything. But as i said before, when the lights are off, that fog light looks darker on the inside. Maybe the reflective coating is coming off?
RE: Dim Fog light
[align=left]Make sure the fog light assmembly itself doesn't have gunk in it. I had to take my whole assembly out and re seal it so water and gunk wouldn't get into my fog light. Becuz one of my fog lights were brighter than the other.
[/align][align=left] [/align]
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
