Wheel size ???
RE: Wheel size ???
+1I would change the same thing. Deep dish would look so much sicker.
ORIGINAL: Injected97GT
my current street wheel/tire combo is 17X9 all around, 245/45/17 fronts. and 275/40/17 rears. the only thing i would change is going to a 17x10.5 and a 315/35/17 rear. fronts, you dont want TOO wide on a DD, you are just going to pull all over with every bump and crack in the road. it can actualy hurt the handling. 255 is as wide as i would go up front. if 275 rubs AT ALL, even "minimaly" its too wide. Nothing should rub, scrape, pop, crack etc.....
RE: Wheel size ???
dub's are gross but check out those rocker panel stripes! def. badass[8D]
but yeah 17's or 18's would be your best bet and trust us, you'll want to lower your car after getting wheels
11-10-2015 11:39 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
09-03-2015 07:14 PM
