what predator tunes makes best performance?
What Should i Set these at to gain the optimal performance gains?
1)Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
2)Timing table (+10% / -40%)
3)Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
4)Fuel table (+40% / -15%)
5)Idle (+/- 20%)
thanks
5)Idle (+/- 20%)
thanks
RE: what predator tunes makes best performance?
I was able to bump up my timing another +5%. I went as high as +8% but it would ping under heavy load at highway speeds.
I wouldn't mess with the air/fuel ones without a dyno.
ORIGINAL: propellerhead
thats weird... i run 91 and i upped the timing all the way(+10%) at both the 2-4k and 4-7k range ..... i have no pinging ...
so id say for timing up it all the way , and fix ur speedo for gear swap if u need to... but other than that just use the tune that the thing comes with , its good enough and u know itll work, u dont want to screw around w/ the A/F unless are going to use the predator as a diagnostics tool and im not even sure if it does it but that would be cool, u could look at your a/f numbers through out the RPM... i thin kit does because its a digital wideband... anyone know if it does it forsure... iw ant to see what my A/F is without taking it to a dyno tune...
anywyas the moral of my story... use the performance tune that the predator comes with... change the timing to all the way up(+10%) and if u need to, fix ur speedo as well... but dont mess around w/ the a/f unless u know what ur doing
ORIGINAL: GT1999
5)Idle (+/- 20%)
5)Idle (+/- 20%)
