Cylinder heads??
RE: Cylinder heads??
Ill make this short. It would be easier/cheaper to do an entire 4v engine swap. The resulting sub 9:1 CR from a 4v head swap would suck for ann/a application. So, yes the heads will bolt up, but there is a ton of extra work/parts required....
ORIGINAL: defconfire
What about an FI application? I never really looked into this as a feasible option, and wtf would you do about the valve timing?
As for the valve timing, you would need the complete 4v camshaft timing setup, 4v ECU, intake manifold, throttle/cruise cables, the list goes on...
