PROBLEMS WIH SHOCKS! HELP! *PICS!*
RE: PROBLEMS WIH SHOCKS! HELP! *PICS!*
ORIGINAL: defconfire
Suggustions on what to replace with, should I go with a front drag setup or should I stick with my current auto-x and track setup?
edit: why would i have to replace both sides? do you think the rebound has faded over time?
As for what you should go with, you're the one that drives the car. If you Auto X why would you go with a Drag setup?
I might as well just replace them both with what I've got now. Im ok with them, they just dont hook-up for launching. Which is probablly more related to my factory Traction t/a's[8D]
ORIGINAL: POISND U
Replace it.
My front drivers side shock is "leaking" if I touch the stiffness adjuster on the top of the shock a little bit of fluid leaks out. What should I do?
+1
