Cam install
Cam install
im getting my stage 1 cam in the next couple weeks, also i bought the valve springs just in case.
so what else do i need for installing the cams? do i need the cam gears?
what about tunning it? i know it should be custom tune but can i doit with my predator? or but it on the dyno?
thanx!
thanx!
RE: Cam install
you really dontneed the springs for most stage ones but its a good idea to get them anyway. yeah the car has press on cam gears so you will need a set of bolt on cam gears which is like 80 bucks for the pair. and wouldnt suggest using a predator to tune it get it dyno tuned. good luck
RE: Cam install
ORIGINAL: 01snake
if your gonna go threw all the hassle atleast do stage 2's. and i hope you are getting head's or you will not get your full potential
RE: Cam install
ORIGINAL: 01snake
RE: Cam install
ORIGINAL: 01snake
