Speedo Recall....Twice?
RE: Speedo Recall....Twice?
The closer you get to matching the sidewall ratio the less likely you need to recalibrate the speedo. It may still need a little but with a 315-30 you are very close to the factory size that it shouldn't cause a noticable difference.
Ok guys is this right?
Stock tires: 245/45/17 =245*.45=110.25/2=55.125mm sidewall
New tires: 275/40/17 =275*.40=110.0/2=55.0mm sidewall
Would this setup work without a recal? Only .125 of a mm difference...?
Mach MY B, I thought a stock tire was 245-40 not 45. A 315-35 is the tire you need.
.125mm = .005 of inch. A 275 - 40 is the tire size you need. Your off by only 5 thousands which is nothing
Stock tire size is 245/45/17....I used 15' in the previous post. I edited it now.
So I think the 275/40 series will be OK? I want the same tire all the way around. I have it lowered so 315's wont work. I am just worried about the side wall thickness.
