Sequential tail lights binking too fast...
Any ideas on how i can fix this problem. They work like they're supposed to, but they blink a bit too fast. I've heard there are relays, but I can't really find anything specific. Can someone link me to a fix? Appreciate it.
RE: Sequential tail lights binking too fast...
you will have to find a different set that blinks slower. you will not be able to mess around with the setting.
i have the Web Electrics ones, i think the flash pattern is perfect.
I got mine from MM electronics, I think thats the name, off ebay. I think they blink too fast too. I should've gotten the "chase" type of lights. Those are more defined. Anyway, bump. Just in case someone does know how to tinker with these ones.
ORIGINAL: Aereon
It sounds like you didnt change the flasher relay. which kit did you get?
ORIGINAL: kenv
I think you are right. I read somewhere that you have to use a mechanical relay like they had in the older cars.
ORIGINAL: Aereon
