are these good subframe connectors to get?
I need subframe connectors for my Saleen S281. Dont know anything about them, just the end result is good. Are these decent ones to get and will a shop be able to weld them in without any problems. Thanks.
http://www.mustangtuning.com/stfulesuco.html
RE: are these good subframe connectors to get?
I have read that some subframe connectors will not fit if you have aftermarket exhaust sytems, espcially on verts such as mine..... Did I read a bunch of BS or is that at all accurate?
[sm=bs.gif] I think that it is a bunch of BS!! If you look under your car you can see that the frame is way away from the exhaust, there are some pics of cars on here with sub-frames if you do a search. But just look under your car and you will see that they are about (12"-14" might be more or less) from the outside edge of the car so there is not going to be any problems with a exhaust.
They will not work if you have a side-exit exhaust. Otherwise you're fine. And now I believe someone makes a special side exit exhaust to work with the connectors.
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
09-01-2015 08:16 PM
