my car scrapes on everthing
I have a side exhaust and my car is lowered 2',Does anyone else have problems with clearance with these side exhaust's,I cant even go over speed bumbs,Or were mine installed wrong????????
RE: my car scrapes on everthing
Nah a 2 inch drop with side exhaust would def scrape alot on on even surfaces. I've the eibach prokit with no iso's and its not bad but everyonce in awhile the h pipe will scrape on oneven surfaces
Lowering a car makes it look and handle better but you loose the clearance and comfort with it. You have to give up that for the look. I chose not to lower the car I have now because my last one scraped all the time and rode like a four wheel drive with a two inch drop.
its just frustrating,I can barely get into my conda's without scraping on the speedbumbs,And i got to map out the way im going to go so I wont scrape going certian ways with bumps,my mufflersare about my 4-5inches from the ground[:@]
I used to have borla side exhaust and I scraped everywhere with stock suspension.
Your muff. are 4-5 inches off the ground? You should feel lucky. I put eibach sportlines on and now my flows are sitting about 1 inch off the ground. It's getting annoying.
