turn signals dont work??
my turn signals dont work... im wondering what could be wrong with them? the car sat forever and now that its running when i hit the lever up or down neither work... although if i move it slow enough to one side you can see it try and kick in.... where is the relay for the turn signals? i checked the fuses and they are all good.
RE: turn signals dont work??
hmm check your flasher, if not that then id check a relay, probably the flasher though. not sure where its at on your car, check your owners manual or goto autozone and get a manual on it.
ok.... i thought that was considered the turn signal relay... hmm... i wonder if its behind the glove box? because there isnt one under the hood or under the dash in both fuse panels.
There are 2 fuses that feed the "Electronic Flasher" "Solid State Module".Fuse #18 and #13. Also check the hazzard switch, see if they flash. I can,t help with the location of the flasher but someone will know.
yea, the hazzard switch works.... today for some reason they worked after work? but then after about 5 minutes of using them on the way home they cut out again... sounds like a short or loose connection?
