Stock 4.6 Motor
Stock 4.6 Motor
Im about to install another stock 4.6 motor i got for 900 w 3k & tremec tranny of an 04 gt, i got a 00 gt. My question is what mods should i do before installin the motor so they wont charge me later for all the extra labor. I was thinking P&P heads? Long tube headers? what else can i do? im in the direction of supercharging....help plz! thanks!
RE: Stock 4.6 Motor
will it make a big difference w blower cams??? i wanan boost 8-10 pounds supercharged...the p&p heads i see their stages or something what stage should i go? and i believe cams are the same thing w stages??
RE: Stock 4.6 Motor
A cam install isn't that bad when the motor is in the car. Takes about 4 hours to change both cams and install new springs. The headers are what your gonna wanna do for sure! I would put in a 180 thermostat and Paint or powder coat everything you want done now!
RE: Stock 4.6 Motor
If you're only looking to run 8 psi I wouldn't worry about blower cams unless you have the money to burn. Cams are expensive and you won't get a lot of bang for your buck at 8 psi. And it's not a big difference whether the motor is in the car or not. The only thing I would go ahead and do now is headers. That will save you a lot of time in the future.
musnicki
09-23-2015 07:11 AM
