Superchargers?
RE: Superchargers?
I'm piecing mine together now:
Head Unit, brackets, oil plumbing, idler pulley = $1065
Complete bolt kit from ProCharger = $80
Intercooler kit from Ebay = $300
Fuel Pump = $127
Injectors = Still looking for a set of 42lb... approx. $200
Total so far: ~$1775
I'm also piecing together all the stuff to install my PnP heads:
Patriot Stage 2 heads = $800
Comp Cams = $600
Stock Windsor Valve Covers = $95
Valve Cover Gaskets = $42
Head Change Kit = $118
Locking Header Bolts = $52
Lower Intake Manifold Gasket = $33
Total for Head install = $1740
I can't wait to get all this installed.
Fuel Pump = $127
Comp Cams = $600
RE: Superchargers?
Go to page 6:
http://www.superchargersonline.com/d...fh4fl218im.pdf
2E229-130 SUPERCHARGER (1900 You have to call them to order this head unit kit).
4FH111-041 MOUNTING BRACKET KIT (229)
4FH112-010 AIR INTAKE KIT (204)
4FH112-020 DISCHARGE KIT (189)
4FH130-026 OIL FEED KIT (22)
4FH130-036 OIL DRAIN KIT (23)
4FH110-040 COIL BRACKET KIT (57)
Subtotal = $2624 + $30 for shipping when they discount it.
Don't get the FMU or the T-Rex listed in the link. Instead, geta fuel pump/ injectors. If you're pushing over 400hp, you'll need a mass air meter. Of course, you'll need a dyno tune also.
Brand new supercharger kit for 3K.
