WTF JLT RAI install pls help
i go to install my jlt rai with very vague instructions and i have a huge problem, it says not to reuse the maf screen which makes perfect sense, but when i bold the billet adapter to my maf, they arent flush i.e the billet adapter and the maf have a small gap inbetween them. the bolts are also way too long and stick too far out causing them to be in the way of the filter piece. what should i do to fix this, i need a tight seal between the maf and the adapter and that isnt happening now
RE: WTF JLT RAI install pls help
This is just an idea, but maybe if you could find a large O-ring at a hardware store you could put that in there to seal it up. Just make sure it is slightly larger than the opening for the air to flow through without obstructions.
i finished installing it so i cant take pics, but basically, between the maf and the adapter there was space that looks like a gasket should have been there, i ended up just leaving the screen in so i would have a seal. seems to work fine
