Trouble codes , wiring short and electrical problem,HELP! - Page 2 - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Reload this Page >
Old 01-09-2008, 04:27 PM
MaKaVeLi
Default RE: Trouble codes from the predator
after from bieng repaired
MaKaVeLi is offline
Old 01-09-2008, 06:41 PM
MaKaVeLi
and if i changed the PCM, do i have to re-tune the car?
MaKaVeLi is offline
Old 01-09-2008, 06:56 PM
01blkonblkGT
do you mean if you change the computer do you have to re-tune it? i think you do. i believe Ford uses the same computer for multiple vehicles. i had to replace the copmputer on my car due to wiring short and the dealer had to program it for my car.
if you think your computer has a problem, take it to the dealer. the computer is warrantied for 8 yrs or 80K miles i think
01blkonblkGT is offline
Old 01-09-2008, 07:10 PM
MaKaVeLi
ORIGINAL: 01blkonblkGT
my car run over 115k
anyway
if i have to change the pcm
do i have to upload the tune from my car to the tuner? and after that install the tune to the new pcm?
and would the trouble codes which i stated above would be fixed?
EDIT:
by the way
all these problem because i had wiring short!!
MaKaVeLi is offline
Old 01-10-2008, 10:14 AM
MaKaVeLi
bump
MaKaVeLi is offline
Old 01-10-2008, 04:57 PM
wwmost
you cant load the stock tune back on your car? if you can load the stock tune on your car i would do that now. and rule out its the actual tune from diablo.
wwmost is offline
Old 01-10-2008, 05:33 PM
MaKaVeLi
ORIGINAL: wwmost
why should i load the stock engine back to car? i think i try this one and after that i get many trouble codes, when when i try to load the diablo tune back to car i had many problem to do that and refuse to load it back, but some howi manage to load the diablo back to car and had no trouble code beside the p1000
MaKaVeLi is offline
Old 01-10-2008, 08:44 PM
wwmost
obviously there is somthing wrong with your tune if you keep loading it and reloading it and somtimes you get the codes and somtimes you dont. load the stock tune and check it. that sucks if you lost your stock tune though.
wwmost is offline
Old 01-10-2008, 08:55 PM
MaKaVeLi
ORIGINAL: wwmost
damn that wiring short! so what to do if i lost my stock tune? buy new pcm?
MaKaVeLi is offline
Old 01-11-2008, 04:54 PM
MaKaVeLi
Default RE: Trouble codes , wiring short and electrical problem,HELP!
bump i realy need help!
MaKaVeLi is offline
Quick Reply: Trouble codes , wiring short and electrical problem,HELP!
Featured Sponsors
