bad fuel pump?
bad fuel pump?
Well my fuel pump has been pretty loud so I decided to go ahead and buy a SVT focus one. Well I dropped the tank an pulled the old one out only to realize that the connector wasnt the same.So I put everything back, but now on top of it the pump being loud, the car bog's pretty bad about 80% of the time when I give it gas. Do you think when I pulled it out that I just made the whole thing worse?It nevr bogd before bt since I went to change it out it has been. Like I said it was loud to begin with and now its loud and the car runs like poop when I step on the pedal.Any ideas?Thanks, John
By the way if anyone wants to buy that SVTfocus pump they can for what I bought it for which was $75
RE: bad fuel pump?
hooked a fuel pressure gauge up to it and it said 43 at an idle and stayed there when I gave it gas.When I discount the battery for about an hour it will run good for about 30 to 45 minutes and then starts doing it again.any ideas?
RE: bad fuel pump?
you can change the connector style... some fuel pumps come with a new connector for them so you can just cut and splice the old ones... if you want i can ship you my old connect that i no longer need from my fuel pump since i no longer have the returnless system with the pump in the tank.
