swaping cams again..
RE: swaping cams again..
ORIGINAL: yelw02GT
who makes VT cams now, didnt they go under? i heard its under another name, but same people id like to stick with VT
I believe I'm going with these guys for my cams(Formally VT) as opposed to my original decision to go with Anderson Ford
ORIGINAL: lizzyfan
The Comp cams, right?
ORIGINAL: racer02GTstang
i tried installing a set in my friends car and even with some cam gears i couldnt get it to work.
but i put a set of vt stage 3 cams in my stock shortblock.
The stage ones are close to the Comps you are talking about. The 270/274 is the advertised duration, not the .050" duration you listed for the stage 1 cams. The advertised duration of the Stage 1's is 269/271 so you aren't steeping up much going to those Comps. My Stg 2's have an advertised duration of 270/280. Hope that helps.
Im also working on a few more 2v grinds, as well as 3V and 4v as well. I don't necessarily believe everyone needs a "custom" grind but i'd like to have a few more off-the-shelf grinds available to choose from.
junior04
09-28-2015 10:53 AM
