Air bag light
Air bag light
I have a '97 GT, I removed the stock steering wheel, now the airbag light is on. How do I get it to turn off? I tried removing the fuse(s) under the dash, light is dimmer but still on. Can I just remove the bulb behind the instrument cluster? Or is there something else I need to do?
RE: Air bag light
Placetwo 4.7 Ohm resistors (1/4W or 1/2W is fine) in parallel across the air bag wires (gray/onange and gray/white on an '03) and the resulting 2.3 Ohm value will trick the air bag controller into thinking the air bag squib is there and working--light off...[/align][/align]The clockspring will have to go with any standard aftermarket wheel I've seen, it's a big chunky thing.[/align][/align][/align]The MOMO hub I used has three brass slip-rings for horn/etc. I made a custom carbon brush and holder from a 3/8-16 nylon bolt and an old spare electric drill brush to feed the horn.[/align] [/align]
