Whats your input on this setup?
I have a 2002 gt 4.6l 5spd with 55k miles...my current mods are:
75mm throttle body, upper intake plenum, steeda underdrive pulley set, aem cold air intake, zex 100 wet nitrous kit, nos purge kit, king cobra clutch, 3.73 gears (full posi), b&m shifter, eibach pro kit 1.5" drop kit, roush white face gauges, sct x3 flash device with dyno custom tunes, mach 1 grille delete, carbon fiber cowl induction hood, window tint, billet pedals & shift ****, sparco style leather seats, cobra wheels with 10.5" rear tires, pypes offroad xpipe, slp loudmouth stainless steel exhaust,i think a couple of other things too...cant remember it all?
im considering going all out...and i would like to know everybodys opinion on what kind of hp #s i might be looking at with the setup i have plus the following modifications..also, if any of you have the following for sale...let me know...i may get back with you witihin the next few weeks..im considering the following setup:
vortech v1 supercharger kit(12ish pds boost)
crower stage 2 blower cams or other cam setup?
patriot stage 2 heads with springs/retainers
melling high volume oil pump
complete gasket set
typhoon polished intake manifold
stage 3 clutch kit
long tube headers
clevite 77 bearings
hbeam rods
mahle forged pistons
file to fit piston rings
forged stroker crank (5.1)
upper & lower controle arms for the rear
swar bars front & back
aftermarket shocks n struts
10.5" nitto drag radials on rear
subframe connectors
strut tower brace
what kind of #s would i be looking at?
complete gasket set
stage 3 clutch kit
long tube headers
clevite 77 bearings
hbeam rods
subframe connectors
strut tower brace
RE: Whats your input on this setup?
with your nitrous spraying maybe 350-400 depending on your tune and n/a around 250-260. Mustangs Unlimited has a complete 5.1 stroker kit for $1500. Everything is included even the rings and bearings. I ordered one for my car just havent had it installed yet. If you installed the heads, cams, stroker, blower, and sprayed you could be anywhere from 500-600hp
