TKO500
TKO500
alright when you guys swapped yours out, what did you do for the reverse light sensor, did you take your T3650 one and screw it in or did you splice the wires and find some nuts to screw down on each of the posts? i am still without reverse lights because the connectors did not match up.
RE: TKO500
ORIGINAL: lizzyfan
I ended up silver soldering the wires directly to the lugs on the fitting that came with the TKO and encased all connections in epoxy glue. It's still working good!
RE: TKO500
ORIGINAL: I G Joe
just as long as you keep the solder seperate right.
ORIGINAL: lizzyfan
I had a shop install my TKO and he never installed the light sensor so me and a bud had to figure this out, what a nightmare! All good in the end though!
travisl1213
02-10-2008 02:24 PM
sarpicaste
Mustang Videos
10-18-2006 05:33 AM
