installed my tb and now my cel is on
so installed my tb and it has been ideling high and sometimes it stays in one spot for a while so now my cel is on.
the code is p1506 idel control overspeed how can i fix this cuz the car is running like crap. i will let go of the gas and the car keeps running the same speed
RE: installed my tb and now my cel is on
no i did not some one told me that if i did that that all it would do is turn the light off but the problem would still be there should i do that and go from there is there something i can do with my diablo tuner to adjust the idel because i do not see the idel thing on the tb
DTC P1506 points to a damaged or improperly installed/wired IAC. Here's a link to the possible causes from the '03 shop manual. No amount of KAM clearing or resetting the idle with a tuner will fix these problems. If you unplug the IAC at idle on a warmed up engine the idle speed should change. [/align][/align]If it does not change speedthen the IAC is bad or not being controlled properly.[/align][/align]Re:clearing the KAM, whoever told you it would only turn the SES off was wrong--the PCM stores short and long term fuel trims, idle speed trim, and other information related to variations in sensor outputs, etc. [/align]
It's not inconceivable that an incorrect or bad TPS could cause the problem, however the computer would most likely be reporting that as well. [/align][/align]Won't hurt to put yours on, but you need to check the IAC stuff on the shop manual list if that doesn't clear things up...[/align]
