Anyone have Comp stage 3 cams?
RE: Anyone have Comp stage 3 cams?
ORIGINAL: Nitti00GT
He said the duration was 278 with a .550 lift
ORIGINAL: rmr1923
i hope 278 is the "advertised" duration, but the duration @ .050" lift is a more relevant figure. the cam's duration and lobe separation play the biggest part in determining what rpm range your engine will make the most power in. generally, the higher the duration, the higher the usable rpm range; and i think (can't remember for sure) that the lower the lobe separation, the higher the power band too. back when i built circle track engines, we usually had maximum cam lift rules (street stockers couldn't have more than .460" lift), but no rules on the duration and lobe separation. Isky Cams made some .450" lift cams with 234 degrees duration @ .050" lift (i believe the advertised duration was somewhere close to 290 or 300; those duration figures are usually seen on cams with WAY more than .450" lift) with 112 degree lobe separation, and even though the cams didn't have high lift, they would turn up some pretty damn high rpm. power didn't kick in until above 4k and i usually hit about 7500 by the end of the straightaways. when you're selecting cams for your street car, you don't want too high a duration because you'll sacrifice a lot of bottom end. you'll still make those peak HP and torque figures that you're looking for, but acceleration and driveability is more about the entire power band than just peak figures. remember, HP is an engine's ability to produce torque overtime (hp = torque x rpm / 5252), so a solid torque curve should be a higher priority than some peak HP figure at some far-off RPM.
ORIGINAL: Nitti00GT
Its too much cam. With your ported heads go with a stage 2 or so. Even with teh stage 2, your not going to see that much of a gain over stage 1s at this point though...
He showed me the cams and gave me the cam card yesterday. The specs are .545 lift and duration is, intake 242 exhaust 246 @ .050. They are the XE278AH cams. I am prolly just going to stay with the stage 1s I have and just get it tuned as soon as I get my intake and gears. Thanks for the help everyone.
ORIGINAL: Nitti00GT
Yeah I actually go to an automotive school and I just got a 100% on my cam and valve test lol. Well I have been debating the cams for a while. The guy who put my motor together told me I have stock rods and a little bit better than stock crank. I have notched pistons to support the stage 3 cam he said. I am just going to stick with the stage 1s I have now, its like a 226 duration (not sure if thats advertised or at .050). For what I am going to be using my car for the stage 1s will be just fine. Sucks that our motors can't do much n/a but hey I am gonna save my money to make my car look as good as it sounds right now. You can't really hear the cams but it runs pretty good til 3500 then it pings like crazy. I am prolly going to be getting it tuned next month, til then I'll just rock my dads V6 vert auto [:'(]til my car is tuned. I will post numbers when it's done. I was hoping for 320-330 but from what I hear that might not be possible with full bolt ons and what's in my sig.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
