Looking for some woffer advice
RE: Looking for some woffer advice
Ok while i dont have a saleen the trunk size is gonna be pretty much the same....
If your trying to find a single box to hold both your 10"s GOOD LUCK its damn near impossible to fined a dual 10" that will fit through the trunk opening... selection in your area may be better but what i was forced to do (and in the end i'm glad) was buy to single boxes... ported or unported boxes thats totally up to your preferance (ported boxes tend to make you feel the bass hit when your ystem is cranked.
if you havent allready upgraded your stock speakers you may want to consider that too as stockers wont keep up well with highly amped subs
You can fit two 10's in a single box easly into your trunk, most 10's have a smaller mounting depth and require less air space, just get a sealed box, 2 JL's, try the W1V2's they are new but the ones i have put in cars sound awesome, but if you really want to hit and sound clear, just put one 12W6V'2 with a vented box, and promise you that you will love either set up. Oh-yeah next time you post make sure it's in the audio section and Welcom To The Forum's. There are also plenty of other setup's that you can read about in the audio section that will give you many ideas, but 2 10's is easy to fit man.
it all depends on the shape of the box you want... around my area you cant find a single box that il fit through the trunk opening (which sucks because once in there would be plenty of space) but then again the box design i wanted did limit me some.... boxes where the sub is angled would be much easier...
Omgitsa88Stang
10-05-2015 07:33 AM
