pi swap port and polish or not?
RE: pi swap port and polish or not?
Yup! There are benefits. If I had the extra money I would do it. You could probably see an extra 10 - 15 HP. I hope you also plan on running shorty headers or LTs because there is no point and making the top end breathe better if you don't let it exhale better.
You might want to look into the stage 2 cams too. I think i have seen a couple of posting saying that the stage 2 were a little bit better than the stage 1.
ORIGINAL: Stangatic
and a port/polish is definitely a good idea if you can afford to have it done. i'm not sure how much you're spending on the PI swap, but you can get a set of Patriot Performance Stage II PI heads for about $1300 from Brothers Performance (with no exchange required, i know that some places require a core exchange). if you've already got your heads then just get them ported and polished, but if you haven't bought them yet (i've seen the PI heads go for about $700-$800 for a pair), it might be best to just buy ported heads and then bolt on your VT (or CMS) cams.
ORIGINAL: dbs96gt
I already have shorties on it. I was thinking of doing the stage 2, but wasn't real sure about any ptv issues.
The patriot performance heads are what I was thinking about going with. Will I need a tune right away if i go with stage 1 or will it sufice till i get the extra cash?
Hey dsm you know of any tuners in the area? I'm only half an hour from you
i can't really tell whether or not you'll need a tune, because it depends on a lot of variables. i think that CMS advertises that their stage 1 cams can be used with the stock computer, but if you're going to get ported/polished heads then i would definitely get a dyno tune pretty soon because the combination of the hotter cams and better-flowing heads will definitely throw things off with your current tune (you'll probably be running lean). do you already have a tuner or are you running the stock tune? i know it's tempting to just go ahead and do the PI swap and be done with it and then save up for a tune later, but you'd hate to spend all that money and have something bad happen, so even if you go ahead and order all the parts, i'd wait until you know you have enough cash for a dyno tune before you put it all together.
