Engine or pulley whining when cold
ok, when i start my car up when its cold out below 20 degrees i get a LOUD whining sound at idle for about a minute until the engine warms up a bit, then goes away (basically it sounds like a procharger at 20lbs, lol, no joke!!) then if its about 30 or 40 degrees out and the engine is cold is doesnt whine at idle, just when i rev up each gear when driving. then goes away after a minute.
i thought that it was the belt, changed that, no cigar. WTF, lol.
also i am selling this car at the end of March, so i want to fix it!! if you want i might be able to take a video, depending on the weather (temp). my next guess would be one of the two idler pullies.
RE: Engine or pulley whining when cold
I had the same problem. Mine sounded like a bearing in a pulley. Changed both idlers...nothing. Only happened in cold. Changed belt nothing. A friend changed a belt about a month later, i was like yo lemme try this belt on my car quick, it was agaterback. No noise. If you didn't put a gaterback in, go to autozone and pick one up $33.
ORIGINAL: MACH5IVE
I had the same problem on my old gt and swapped out the right side idler and the whining went away! What side is it coming from!?
the belt was easy and cheap to replace, so thats where i started. i am 99% sure its not the belt. ive hit both the new and old with some dressing, nothing.
HIS S-197
08-10-2015 05:47 PM
