Could it be the PS or the susp.
When I'm turning the wheel to far left of right the front driver side wheel makes the whole car shake and makes a horriblegrinding noise like riding with a flat tire. On the out side the wheel looks like it is popping like it isn't ontight enoughbut I checked it and it was. My car also likes to follow grooves in the street, the entire steering wheel turns and it feels harder to turn then the other cars I drive that have power steering. The wheel also turns to the right when I brake, and I have to turn it kinda hard for it to straighten up. The drivers side front wheel has really bad uneven tire wear so that could be the problem with the front tire. I just want to know that I have done everything I could before I take it to a shop.
RE: Could it be the PS or the susp.
Its more then likely your wheel bearings have gone out. Jack the car up, and see if your wheel can move form side to side and up and down. If you have movement in there then you need new wheel bearings then come in a complete kit at many parts stores for about 70-90 dollars and will take about 2 hours for both.
ORIGINAL: dennis_112
sounds like bad alignment, one brake could be dragging as well. jack the car up, and shake the wheel up and down to check the wheel bearings, and then side to side to check the tie rods.
Okay I will jack the car up today and see if I can move the wheel. The tire is worn unevenly because it had very little air in it and my cousin was driving it without knowing.It's not lowered and I put new brakes on all four wheels 3 months ago. IT sounds like it could be the wheel bearings or ball joints.
ChrisZio04GT
20
06-06-2007 08:26 AM
