Wan to put 03/04 Cobra engine in 00' GT possible?
RE: Wan to put 03/04 Cobra engine in 00' GT possible?
Yeah, because after I'm done all my appearance mods, instead of tuning a GT I'd rather just spend 4-5 grand and dump the Cobra engine in there. I bought my GT for so cheap that I'd basically be getting a Cobra for super cheap.
Basically if you have the money to do the swap, you have the money for a Terminator.
Ballpark 10K just to get a running 03/04 Cobra engine and trans. Generally you're not going to find a deal, anyone whos selling an 03/04 Cobra motor knows what they've got. And even if you do, you're not going to find one at half price.
If you want to spend 5K, buy a supercharger, exhaust, and gears, and you'll run with stock Cobras.
ORIGINAL: Pauly_B
alot of work and it just not worth it
ORIGINAL: SixEight
ORIGINAL: 99 35th gt
i wanted to do the same but i have an auto, and finding an auto cobra, yea i dont think soo.
Im not at all trying to be rude here guys but please dont post on subjects that your not perfectly clear on. It just persuades someone from doing something that could benefit them. To the O/P YES!!!!! It is very possible to install an 03 motor into your GT, I would recommend going with the T-56 as well but you could still make it work with your 3650. I know of someone who personally retained their stock GT PCM chipped and tuned it to work with an 03 motor/trans, If you dont want to go that route you could always buy the cobra pcm and core your GT one. Also a couple other things I would recommend changing over would be the cobra fuel tank and pump assembly possibly just the pump, you might also want to look into the radiator and A/C condensor. (which will help with engine temps). If you need anything else I'm sure I can help you with it, if I dont know I can definitley check with someone else who does
ORIGINAL: JL6585
