do i need bigger injectors.
with the mods in my sig do i need to change my fuel injectors. if so how much.
i am only doing a 50 shot dry.... hey its doing the trick to beat some ss camaros
with the mods in my sig do i need to tune my car or after i change the injectors do i need to tune it i have a diablo tuner but i mean like have a shop tune it
RE: do i need bigger injectors.
I don't know much about nitrous but I would definitely get a tune. Your a/f ratio has to be richer when you run nitrous, and unless you have a wideband there is no real way for you to tune it correctly yourself. A 50 shot might not be enough to really mess things up for you, but you certainly won't be getting the most out of it without a good tune. You will benefit from a dyno tune anyways given the rest of your mods.
edit: As far as injectors, you'll probably be about 290-300rwhp with your current mods and a 50 shot which is pushing the limit for the stock 19s.
you wont need a tune or bigger injectors to run a 50 shot, with shots around 100 ignition time is recommended to be changed( 2 degrees per 50hp to be on the safe side 1 works just fine though).
But then agian you wont NEED them but all of it is recommended to be as safe as possible
ORIGINAL: 2000GT4.6
Don't screw around with the dry kit, just get a good wet kit and be done with it.
ORIGINAL: ninelives19821
+1 the wet kit will give the motor the fuel it needs instead of you depending on your injectors to make the increase. If your only running a 50 shot it may not be a issue but wet kits for sure give you piece of mind knowing it will make sure you have enough gas and not maxing out your stock injectors. I would upgrade the fuel pump though
ORIGINAL: 2000GT4.6
ORIGINAL: 1SLO85
ninelives...what are your car specs for 330rwhp N/A?
ORIGINAL: 2000GT4.6
ORIGINAL: tbirdscwd
Not to thread jack but, 1SLO, weren't your final numbers on the bucket like 341 N/A?
ORIGINAL: 1SLO85
ORIGINAL: 2000GT4.6
