Turbo AND PI swap? Is it needed?
I posted this in the Pipes Boost and Juice sections, but hits are hard to come by over there Soooooo:
Ok, I think I might go turbo. Who knows, but for now it's the best power adder deal I can find. SO, let's assume that I do go that route. I am looking at a single turbo (60mm, dual ball bearing) kit at the moment. I understand that this kit can take me to 600 hp, so it'll work just fine
Here's the questions: if I can reach that number off the turbo alone, is it worth it to do the PI swap at this point? I have a 97 GT and can get a good deal on a PI swap, but do I really need it? The only reason I think I would get it is to get more low end torque so I can get to the boost a bit quicker. Any thoughts?
RE: Turbo AND PI swap? Is it needed?
well to make 600 hp ur gona have to built ur whole motor anyway...so u might as well to the whole swap. any one else with a new edge that was trying to make thoes numbers would have stage x heads and cams plus a p51 or whatever intake, so if ur gona go for thoes numbers then u might as well go all out
Yea that hp level will be easier with pi parts or you could forge your bottom end and get the svo npi heads and svo npi intake but those are very expensive parts. the npi intake and heads are horrible and a singel turbo kit will not make that power on a stock motor.
ORIGINAL: Chris98Gt
ORIGINAL: trickdriller
Welll dont do a stock PI swap. Buy the stage 3 D&D PI heads on ebay they are only 1300, your wasting your time to do a NPI Turbo, it can make good power, but for such a cheap uprade, there is no reason not to do it right the first time
Ok, sorry if I said that incrorrectly. I don't care about numbers really. I was just saying that the turbo can put out 600 hp, that's all.
I just want to make sure that if I get the PI swap, it won't interfere with the turbo. I think if I do the swap and single turbo, I would at least like to see 350, or whatever is ok for the block to handle. I know with that combination I can do much more, but I just want to keep the engine running until I can get the shortblock
You also have to take into account that you will be raising your compressions to around 10.5:1 when doing the PI swap, which is not IDEAL for boosting. You are going to need a forged rotating assembly to run the numbers you are looking for. You could do the PI intake mani, get your heads P&P and some blower/turbo cams if you are planning on boosting. The type of cam you want varies between n/a and boost applications
ORIGINAL: N2O98gt
