stroker kits VS natural stroke
RE: stroker kits VS natural stroke
it just seemed as tho you were discouraging him from the stroker route due to the compression ratio, could of just been the way i read it tho. in my opinion if i was going the stroked route i would go with a 5.4, the larger deck height and stock rod length would prevent the common rocking of the skirt in the lower portion of the bore......... plus i believe the mmr 5.4 shortblock is like 2600 bux.
ORIGINAL: livefast1
ok since you build motors, if i bore & stroke my car from a 4.6 to a 5.0, i have the 4.6 dohc, 97 cobra. how much hp will i get from boring & stroking, of course id upgrade the cams a bit and port & polish the heads. what kind of gains would i expect? just out of curiousity.
ORIGINAL: Ecstasy
ORIGINAL: oxfordgt
Very little gains from stoking a 4.6L since it has plenty of stroke as is. You need more bore to make power but not enough material for it.
the stock 4.6 already has a pretty long stroke in relation to its bore size. just for comparison, the stock 4.6 has a larger stroke-to-bore ratio than a chevy 383 stroker, so stroking it even further would be pretty useless. i've read that you can only bore a 4.6 up to .030" overbore safely, any more than that and the cylinder walls will just be too thin, and a .030" overbore will only gain you about 5 ci, so there's no power to be gained there. you can have the block sleeved and get up to 3.7" bore, which would net you about 305 ci (5.0L), but i'm not sure that it's a very cost-effective option.
We are running a pretty smallmotor with only a3.55 bore. One of the reason we have "crappy 2v heads" is becausethere just isn't enough room for bigger 2v valves. That's whyFord went with 3v and 4v heads. The Patriot stageIII head has bigger2v valves but you have to bore the motor .030 over touse them.
I have read posts from people who were very disappointed with the horsepower that they got from a stroker 4.6. The most woeful was a tale of a guy who bought a stroker short block which gets its power down low, put on new high-flow high-rpm heads, and a mid-range cam. He was disappointed because even with other mods he couldn't make 300 rwhp. I spoke to an engine builder about this and he said it was very hard to talk customers out of the stroker since they were about the same price as a regular forged kit.
I'm pretty sure you will be disappointed as well. A Procharger, like all centrifical superchargers, get its power at high rpms. Putting in a stroker kit which limits your rpms is a waste of the Procharger's potential. Your best bet would be to get a forged short block with the standard stroke that can run 7000 rpms. This will really bring out the F1As potential.
