what cam is right for my car
Old 01-27-2008, 03:45 AM
sleeping stallion
sleeping stallion's Avatar
Default what cam is right for my car
ok so my mods are down below what should i go with for a cam what stage and brand and what springs. after i do cams i will tune it for sure.
sleeping stallion is offline
Old 01-27-2008, 03:53 AM
tbirdscwd
tbirdscwd's Avatar
Default RE: what cam is right for my car
You could buy my Comp Cams Stage IIs, but you will need new valve springs.
tbirdscwd is offline
Old 01-27-2008, 03:55 AM
sleeping stallion
pm me would stgae 2 be good or would stage 1
Old 01-27-2008, 01:22 PM
texas_stang02
texas_stang02's Avatar
i think Comp Cams recommends replacing valve springs with any of their cams, but there probably won't be a huge difference between the power you get out of the XE262H compared to the XE265H cams ("stage 1" and "stage 2"). the 265 will probably open up some more on the top end, but with stock internals i wouldn't really feel comfortable revving up that high. the 262 will probably work in a better RPM range and go well with your current mods. if you plan on doing any kind of head work (now orin the future), go with the 265's cause that will REALLY open things up.
texas_stang02 is offline
Old 01-27-2008, 06:35 PM
tbirdscwd
tbirdscwd's Avatar
265s are the stage II for the NPI mustangs. Stage IIs for 99-04 are 270s and yes Comp does recommend replacing the springs. I personally would never go through the trouble of replacing cams on these motors and only going for stage Is.
mirandaandjimmy
11-16-2015 08:51 AM
ding56
08-14-2015 02:40 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Jacob4589
08-08-2015 11:00 AM
Quick Reply: what cam is right for my car
