adjust cluth tension
My clutch tension is totally messed up because I had no idea which way to turn it...One time I turned it way to the right (when standing in front of the hood) and I was griding gears like crazy with the clutch all the way in...now I turned it back way to the left and it was fine, now it feels like the tension is really HARD....
so what way to I turn it to loosen it, without screwing it all up...
RE: adjust cluth tension
u have to adjust the clutch now...
what u do is grab the pedal..pull up on it until it clicks...then press it down with your foot
did it to me... i forgot to adjust it and it was like really hard and ****
u pull up the pedal..hear clicking...then press it down a couple times you should be ok
ORIGINAL: Wolfe008
yeah, I have an adjustable cable thing...
I tried both things, and the turning of the wheel clockwise seemed to of helped, but it did't last for long, and the tension seems to of returned to it's almost unberable stiffness...
could there be another problem??
