TOB question, just replaced
#24
RE: TOB question, just replaced
took it to another shop and of course they said this is not normal. They want to charge me 500 to rip it out and find out whats wrong. I am not taking it back to the original mechanic...
a) he said he wont cover any warranty b/c I used my parts
b) he is an idiot and I dont want him touching my car again, I would rather pay the extra 500 to have professional mustang people look at it and figure it out.
If my new shop can get some business where we can buy a 2 post lift, I would do the diagnoisis myself, if that doesnt happen soon enough, then ill be taking it to my local performance shop.
#25
ORIGINAL: timeformiller44
lol hey asshat i am also ASE certified..so please spare me... and who said anything about extreme amounts of lubrication.. and i HIGHLY doubt a tiny bit of lube is going to squeeze itself between the flywheel and friction surface of clutch...and if any at all does it will be such a small amount it wouldnt matter... oh and i lubed mine...no clutch problems...
ORIGINAL: Dsmfighter
I'm well aware of wtf is going on inside of a clutch assembly...I'm ASE certified andhave a degree in automotive science. Putting an excessive amount ofwet lubricant on a device which spins at a high rate of RPMSwill causesthe lube to fling everywhere.Excessive wet based lube+ friction material= slipping clutch.You should use a dry film of graphite to lube the bearing. You could use a wet based lube, but would have to be EXTREMELY stinggy with the amount your putting on there.
do u know what it even looks like???
it would have nothing to do with a slipping clutch... the clutch surface touches the flywheel...the TOB is behind the clutch between the tranny...has nothing to do with the acual mating surface of clutch and flywheel
So your transmition instructor told you to put a lubrication on the throw out bearing...which spins...and your not suffering from a slipping clutch?
u do know your suppose to lube the TOB as well... made that mistake....never had a prob with it... removed the transmisson to fix it...put it backtogeather...****er whinned like a bitch...called up my transmission teacher to be like wtf did i do wrong here...he said if i didnt re lube the TOB it prob would be squeaking
[sm=shootshoot.gif]
#28
Ok Ive read the entire thread and I am looking for the cheaper solution to this problem,quadrant/firewall adjuster. I have no time or place to pull out my tranny; I can't wait to graduate. Will this work? Mine sounds like a tin can rattling around in there. Should I also try lubing it up a little too? Lastly, where would I lube and can I get at it through that little cover on the tranny?
#29
ORIGINAL: 99StangGTTN
for whoever said do not put lube on it. I just bought a new TOB today and it came with some white grease to put on the bearing retainer. not a lot but enough to coat the retainer.
thank you
Diode Dynamics
28
05-26-2022 12:02 PM
MustangJourney
09-02-2015 04:32 PM
