Need help from the tech guys....
My 96GT still sports the non-PI powerplant with roughly 200k miles. My buddy in all his brilliance just rolled and totaled his '00 F-150 with the Triton 4.6.If I can get it cheap(I think I can get the whole truck for 1K) should I go after the motor? Are the motors even close to the same as the '99+ stangs?. I had been planning on a crate motor sometime next year. But if his motor is the same as the '99+ stangs, I'd like to just rebuild his on steriods. Thoughts??
RE: Need help from the tech guys....
The only reason for using his block would be that mine is a daily driver. Using his block would give me the luxury of not needing to hurry the process. Build his while driving mine.
my friend had a 99 gt with a 98 non-pi block with his heads, k&n filter, plenum & 75mm tb, with nittos & 3.73s, stock manifolds, bassani o/r x & 2 chamber flows and he was running 12.90's. cuz with the non-pi block & pi heads you run a tad higher compression then with a full pi setup.
You'd be ripping yourself off to buy his truck for 1K if all you really wanted was his block.
You're not in a hurry right now, so just save your money until you can afford to order a short block.
