who has zex nitrous wet kit
#23
RE: who has zex nitrous wet kit
Dude, first off ZEX kits do not suck, that guy doesn't know what the f**k he is talking about, nor can he back up his accusation. Second, do some research before you even think about installing your kit. There is so much useful information on the web and especially on this site, just use the search window and you can find answers to most of your questions. It is true that a ZEX 75 shot will only give you around 55-60 RWHP. That is because ZEX rates their kits as HP at the flywheel. If you want 75 RWHP, all you have to do is increase the diameter of the jets. I don't know why people make such a big deal about other brands advertising 100 HP and delivering 100 RWHP, all that is different is the jetting(which takes less then 10 minutes to swap out). Also, I consider a window switch, a wide open throttle switch, a bottle warmer, NGK TR6 spark plugs, and a fire extinguisher in the trunk mandatory for all nitrous kits 75-125 shot. All the other options I consider optional. You do not need a tune for nitrous. All that you need to do is back off the timing depending on what shot you go with. I ran the 75 shot on my car for about 10 or 12 bottles over 2 years with no tune or timing adjustments and I have had zero problems. Good luck, and get ready to wake up your stang!
#24
thanks man i got it all worked out its set up on a wide open throttle im looking ingetting the blow tube thing due to track rules.
also a gauge and a heater. im auto so i dont no about a window switch
jwog666
12-27-2021 08:09 PM
