I just installed my caster camber plate with 1.5 lowing springs from CJ Pony Parts and now i have a clunk in the front end when I go over bumps. I still have the stock struts and shocks,don't know if they would be bottoming out or not. Just wondering if anyone has had this problem. Ill post pics later when I get to a computer.
Your top shock nut isn't tight enough. That is what happened to me. Did you use a air socket to tighten it up? When you go to get it aligned they should be able to fix that.
I already got it aligned. I had to put the two spacers in with the kit.I put a screw driver in the slot and tightened with a wrench. I'll try to hit it with the impact gun when I get home.
I thightened up the strut nuts and it helped a little. When I installed the plates was I suppose to leave any of the other rubber bushings other than the one under the dust shield.
I can't remember all of it, it was so long ago when I did mine, but I don't think you are suppose to leave any rubber bushings. What kind of cc's did you put on?
