6spd conversion
RE: 6spd conversion
Yeah its worthless... Till you break your almighty t45 trans... with 400hp... I don't know about you but i will never rebuild a t45 and i would never try to make that trans any better. syncro's are junk, the input shafts are junk and the main shafts are week. T56 or tk600 is the only thing worth upgrading to when you break the pos t45
RE: 6spd conversion
^ Agree with the above. It really depends on your application. I am shooting for 1,000hp+ and would go for the t56 to make the car more streetable if you know what i mean! T45s are great transmissions andcan be built to handle high HP.
RE: 6spd conversion
I think it might be worth it if you go with the Viper spec T56, but not the regular cobra/fbody one. I destroyed the 3rd gear syncro and blocker ring on mine at less than 400 rwhp, not that big of a differance between 350 and 400 hp, at least not for the $2500-3000 the swap will cost. Yes a TKO5 or 600 is $2-3000 but they are bulletproof.
RE: 6spd conversion
That short first gear is what gets you out of the hole better. I guess I just don't really see the point of a 6th gear, I had one and almost never used it. The OD ratio in the 5 speed is almost the same as the OD ratio in the 6 speed.
RE: 6spd conversion
ORIGINAL: AmericanRicer87
Right, i like the TK600's and the only problem is the TK500's have a very short gear ratio. and they are a 5sp
As for the fbody/cobra stuff... the advantage is (IMO) that nice middle gear between 4th and 6th giving you that extra shove at 120+
HRnB
GT350 S550 Tech
12-18-2015 09:35 AM
11-10-2015 11:39 AM
YoungStangsMan
09-05-2015 07:01 PM
