Cracked Intake Manifold....Any ideas?
Old 02-05-2008, 07:47 PM
WilsonStang98
WilsonStang98's Avatar
Default Cracked Intake Manifold....Any ideas?
hey guys,
I bought my 98 GT back in July and recently it started losing coolant. I couldnt find the leak for a while but now its obvious that its from the front intake runner, where it crosses over behind the alternator. I still have the old all plastic intake manifold. I doubt ford is going to do anything about it since the recall date is past or whatever. Is there anyway to fix this besides replacing the intake with a new one? Is it safe to drive as long as I keep an eye on the leak or not at all?
WilsonStang98 is offline
Old 02-05-2008, 07:53 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
Default RE: Cracked Intake Manifold....Any ideas?
Replace it. Upgrade to a PI intake manifold... You could drive around with it still leaking, but of course you run the chance of over heating. And you'll be making one hell of a mess. [&:]
96GT226410 is offline
Old 02-05-2008, 07:56 PM
WilsonStang98
Can I get a PI intake without PI head swap? I'm planning on doing it but not right away.
Old 02-05-2008, 08:05 PM
JayBanion
JayBanion's Avatar
I have a 2001 PI intake if you want it. pm me
JayBanion is offline
Old 02-05-2008, 09:03 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
ORIGINAL: WilsonStang98
Yeah. Look up for a write up.
Old 02-05-2008, 09:05 PM
WilsonStang98
I found the write up on this site. Definetly seems easy to do. Thanks.
Old 02-06-2008, 12:51 AM
NinetySix GT
NinetySix GT's Avatar
Make sure you get the aluminum x-over on that PI Intake!!
NinetySix GT is offline
Old 02-06-2008, 01:25 AM
tbirdscwd
tbirdscwd's Avatar
ORIGINAL: NinetySix GT
+1
tbirdscwd is offline
Old 02-06-2008, 01:44 AM
aode08
aode08's Avatar
all the ones, where folks didnt have money for a new intake, jb weld worked perfectly fine.
so do that. Make sure the area is dry and the car sits overnight
aode08 is offline
Old 02-06-2008, 02:57 AM
effingroovin647
effingroovin647's Avatar
Yea mine cracked andi waited a longg time to fix it, if your not going to do it right away, make sure u havent driven it for a few hours, sand the crack with a piece of sand paper, and jb weld it! make sure you get the kind that is good for water welding though! that worked best for me. It will eventually start leaking, but youll only need coolant once in awile!
effingroovin647 is offline
Quick Reply: Cracked Intake Manifold....Any ideas?
