TKO 600 Grinding 3rd (HIGH RPMS)
as title says when racing it GRINDS every time... any suggestions.... if anything no more racing for me, this tranny cost to much as it is... i Dunno if Clutch isnt going all the way down or what, I might Ajust the Clutch quadrent.. Any other Ideas? Thanks.
RE: TKO 600 Grinding 3rd (HIGH RPMS)
Typical of the TKO. Lots of people have the same problem. Most likely, there's nothing mechanically wrong with it. Search around on the forums, there's a few threads about this.
From what I have seen/heard, its mostly the early modle 500 and 600s. My 500 has never ground going into any gear.
Call up tremec or d and d performnace and see what they say, there may be a fix.
mine grinds when i first try to put it in reverse. after it grinds, it'll go in and out no problem. until i move forward again, stop, then try to go in reverse again. hella annoying. my boy at the shop said it'll be fine though, so i guess we'll see. who needs reverse anyway?
ORIGINAL: 2000GT4.6
Is it a grind or are you just hearing the gears clash. damn near all tranys will clash or what you call a grind going into a gear hard and fast. This is due to poor trans fluid. Try going to a royal purple or redline gear oil.
