coilover kit question
Old 02-06-2008, 06:34 PM
boostanggt
boostanggt's Avatar
Default coilover kit question
i just put on a coilover kit and the spring hits the spring body. do they only work on certain struts b/c the springbody doesnt sit level on the strut? it sounds horrible and i dont want to have to buy a real set of coilovers if i dont have to. any help would be great. thanks
boostanggt is offline
Old 02-06-2008, 06:35 PM
timeformiller44
timeformiller44's Avatar
Default RE: coilover kit question
ORIGINAL: boostanggt
thats your problem right there.....
timeformiller44 is offline
Old 02-06-2008, 06:41 PM
amoosenamedhank
amoosenamedhank's Avatar
What is a not real coil over kit?
amoosenamedhank is offline
Old 02-06-2008, 06:53 PM
Fobra
Banned
Fobra's Avatar
I think you asked this earlier, I told you to get KYB gr-2's or qa1s other struts wont work. Also coil overs change your suspension geometry, so often times a 1/4" wheel spacer is need to make the rim clear the spring
Fobra is offline
Old 02-06-2008, 11:20 PM
oxfordgt
oxfordgt's Avatar
what did you put on?
oxfordgt is offline
Old 02-07-2008, 05:38 AM
jmac72187
corner carver
jmac72187's Avatar
If you mean the coilover spring is hitting the inside of the strut tower, you may need to swap your C/C plates into negative orientation. I really have no idea what you are asking or what a "real" set of coilovers is.
jmac72187 is offline
Old 02-07-2008, 09:44 AM
boostanggt
boostanggt's Avatar
i have a coilover kit over the factory strut right now. when i take a hard turn or hit a bump, you can hear the spring clipping the coilover body as it compresses.
Old 02-07-2008, 10:21 AM
Fobra
Banned
Fobra's Avatar
hmmm, well coil overs are more noisey, i need to see a pic of how and where its hitting
Fobra is offline
Old 02-07-2008, 02:29 PM
oxfordgt
oxfordgt's Avatar
Yeah i need to see a pic. If you put some crap ebay kit on thats the problem. The sleeves have to be tight so tight that they are hard to get on the strut.
oxfordgt is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
copestang
10-11-2015 07:17 AM
GimpyHSHS
09-18-2015 12:27 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: coilover kit question
