A stock 5 speed will run anywhere between 13.8 (if you are really good and track prep is perfect) to low 14s with a decent driver. A stock auto will run low to mid 14s. Typically 14.2 to 14.6.
anywhere from 13.9-14.7 depending on any number of factors... elevation, track prep, driver, DA, and the list goes on. The best way is to run it out to the track and see what you can put down
I think you'd be lucky to get into the 13s at all bone stock on the stock rubber.
