How hard to install MM weld on connectors?
I have full length subframe connector, and MM says the proper way to install these is with the weight of the car on all four wheels. Well this is impossible for me cause I don't have a lift. Is this the only way to install these properly? I also have a Strut Tower Brace from MM, but found out it won't fit over my centifigul blower intake pipe! I'm starting to wonder if all this crap was woth the freakin price. Any ideas?
RE: How hard to install MM weld on connectors?
You are most likely going to have to pay for someone to install the SFC's. They are weld in and if you don't know what you are doing, you could burn your interior up.
Do it right or don't do it at all. You need to have the weight on the suspension, you can place jack stands as close to the wheels as possible or go buy four of those drive on ramps, you can get them at Pep Boys. Not doing this can put a twist on the frame, which could cause the car to launch funny or even the doors to not shut right.
