how much would it cost to build up a 2v to hold 600-700 rwhp... and what all to you need as far as rear end tranny and engine.. if the car allready has a auto trans..???
About 20k. You will need to beef up your rear and driveline and add a sumped fuel tank with a twin pump setup. If you have the S-trim Vortech you will end up topping off around 525-550. I have the s-trim and am making 530 to the tires. A t-trim will get you in the mid 600 range but if you are builing the block you might as well go with a larger JT or YSI to get the full potential. It is a tough call to make to build the 2V or buy a terminator. You will defenitly not get your money back on the 2V, and you will need to do work to a terminator to get it in the 600-700 range. I am hoping to get there this summer. 530 is fun don't get me wrong but 650 would be insane.
