Starting from stock!!!!!!!!!
i own a 2000 mustang gt vert. i want to start upgrading my car. i now i need to start with handling n putting the power to the pavement. so any tips on what to get as far as struts, shock, control arms, brakes, ect... Or ideas on where to start im not a real gear head i just like to drive fast n not lose.so lamance terms plz.. i dont want to stick power in it that the car cant handle. also i would like to do a tranny switch to a 6 speed any good ideas would help. one more thing i need a new exhaust mine has a hole in it so this is a priority. i dont want it to soung like a rice burner or raspy nice low tone with bass. sorry about the big list but all the help is appreciated.
thx alot Roger Rabbit
RE: Starting from stock!!!!!!!!!
for exhaust i would go with an x pipe with magnaflow or bassani mufflers, i would go with brembo brakes with 4 piston calipers drilled and slotted rotors checkrim clearance before you buy the brakes some take 17' rims others take 18' rims check with your dealer before buying.
magnaflows.....I would have went with Brembo breaks,but they were a little out of my price range. I went with Baer instead and they work great ***after I had to have a part fabricated to make them fit properly***. Baer knows of the problem, maybe thay have fixed it themselves and if that is the case they are well worth it!!
after u get that exhaust fixed id get some gears and sticky tires. best thing to get the power to the ground it some sticky tires. grab a set of nitto drag radials of bfg drag radials. they are both great tires.and some 410 gears. the car will feel like a totally different car. u could get some upper and lower controle arms after that. i baught mine from www.uprproducts.com for$200 and im happy withthem. depends what u want urcar to do. handle, or hook? starnge shocks/struts are goodfor the track as well as lakewood shocks/struts
Sticky tires
Gears
Control Arms
Springs (Type depends on what you need)
Subframe connectors
Exhaust (Longtube headers, mid-pipe and catback)
Mach/Bullitt/Cobra Brakes
Shocks/Struts (KYB AGX, Strang 10-way, Bilstein, Koni etc.)
That should be good for some basic stuff. If you want more suspension...
Tubular K-member and A arms
Coilovers
Panhard bar
Weight reduction
Gears
Control Arms
Subframe connectors
Coilovers
Panhard bar
Weight reduction
