Cobra Brake Conversion
Hello All,
If you have seen my other postings you probably know that I doing a major overhaul to the suspension and brakes on my car. So here is my question: I purchased a Cobra brake kit with 13"rotors and was wondering if the calipers will directly bolt on to the stock spindles or am I missing a bracket (like the bracket for upgrading to 13"s for the rear.)?
I've already did a forum search and can't find anything.
RE: Cobra Brake Conversion
ORIGINAL: Benr7132
It all bolts up fine. I'm doing my conversion this weekend too. What I'm struggling with are the new stainless lines leaking at the hard line connect...
I think the lines are different for each side and they must go on the correct side or it won't fit properly.
Something like that.
Try searching.
you might be missing a caliper mounting bracket that is required with the big brake upgrade, in order to mount the calipers in it's intended position.
Anchor Plate, RF F4ZZ-2B292-A
Anchor Plate, LF F4ZZ-2B293-A
your missing the brackets. when i did mine i bought it al from a guy that upgraded his 03 cobra to a brembo big brake so i got everything. there is a bracket that moves the cobra caliper a little further up/away so it sits in the right place on the rotor. it looks like a kidney shaped piece about 4"x2" it bolts where your stock calipers go and the cobra calipers bolt to it.
good luck
good luck
Mine bolted right up with the stock hardware. Thigs are different for different years though. I know with my 03, I was able to use the stock banjo bolts and lines (they were out of the stainless lines, but I needed new brakes, so they went down on the price). This, however, would not have worked with an earlier model car.
Call the place you got them from and speak with their tech support. Or call up another place, like buyfordracing, and ask them.
