f/p gauge says one thing but scanner says another
guys, i'm getting two different fuel pressure readings at the same time. the gauge on the rail reads a measly 26-28 psi while a scanner hookedto the odb port reads 40 psi, wtf?
my car is running like crap right now, could this be why? i've tried just about everything else
RE: f/p gauge says one thing but scanner says another
ORIGINAL: Brute03
that was my guess too, but that's an 80 dollar part and i want tobe sure. is there any way the test it with a multimeter?
Have you tried disconnecting the vacum line from the fps. With it connected you should read on your gauge 29psi with it disconnected you should read 40psi. Sounds to me like your running correct.
What is your car doing that it runs like crap?
andrew1969
16
01-08-2016 02:48 PM
