Last edit by: IB Advertising
Browse all: Powertrain Guides
- Ford Mustang Gt 1996 to 2004: How to Replace Oxygen Sensors
Step by step instructions for do-it-yourself repairs
oxygen sensors
RE: oxygen sensors
you have four sensor. right and left bank. 2 on you manifold and 2 behind our cats. Your either running too lean or rich. Are you running a tune or doing it yourself. If your running a or pipe and havn'tconnected the mill conectors, o2 sensors will keep tripping your engine light. If you have a tuner , you can shut your rears off. If your still tripping them and all is done as I mentioned, it's time to replace your front o2's. The code should say one of your banks are running lean or too rich. You could also have a faulty MIL. ALso, if you get new o2 sensors, do not by aftermarket. BUy ford o2 period. I learned the hard way & found out the aftermarket I bought at actionauto from Boush are junk. I returned them because they kept throwing lean bank codes. I havn't had a issue sence w/ the stock ford o2's/. Plan on spending $90 a piece. I run the same set/up as you.
RE: oxygen sensors
ORIGINAL: baino
^correct. Ecstasy, you might search other threads for a cheap o2 sensor site. I recall a discussion about it not too long ago and they gave out a good site for OEM sensors. Cant remember it though. Hopefully its just your mils though
ORIGINAL: swooshonln
4?
there are 2 o2 sensors on the headders and two on the H/X pipe... I dunno about cobra's tho. but the only two that need mils are the two "rear" ones
are we talking aobut the same thing?
4?
they have OE ford ones for cheap.
jwog666
12-27-2021 08:09 PM
