suspension upgrade advice
ok its time for a bit of suspension upgrade. i have a 99 gt and was thinking of putting a 03 cobra irs in it. how hard is this to do and is it recommended or is there another route i can go. whats a good strut/shock to go with? not to sure about lowering. i bought the car second hand so im not sure (the springs look stock) if it has been lowered. all i know is that im lower than other stock suspension mustangs and i scrape my exhaust of every @#$%& speed bump i come across. and its annoying cause vancouver bc seems to have a hard on for putting speed bumps every bloody 15 feet in their parking lots. so any advice would be great.
RE: suspension upgrade advice
When I bought my 99 GT, it had an IRS in it, and I trashed it and threw it out for a SRA. Kinda funny huh?
You can make your SRA handle well enough as it sits. I don't know a whole lot about suspension set-ups for handling, I'm more of a straight line guy, so I'll leave this to the other guys.
I can tell you this. A good lower control arm, subframe connectors, and adjustable shock/strut, will do wonders for you.
seems like the IRS swap would be a pain and that it would be easier and cheaper to just upgrade your straight axle (although i love my IRS). Bilstien are a really good brand though. I like my eibachs, but they came with the kit. just my .02, but i think ZW99GT is on to something with the lower control arms, connectors, and shock/strut replacement.
Alpine, aside from location (Chicago here), we're in the exact same boat. I'm looking at possibly swapping the SRA for an IRS. From what I've read, the swap really isn't all that complicated. But it depends on what you plan to do. Apparently the axles on the IRS are crap once you start adding power, so straight liners would want to stick with the SRA. As for the twisties (which is where I'd like to go), I have to imagine that the IRS setup is superior. And considering there are Cobra guys that want to go SRA for the power benefits, finding someone to swap with (I hope) will not be too terribly difficult.
I hear nothing but good things about the Tokico D-Spec shocks, and there are a number of quality coils, depending on any drop you're looking for. I plan to go for coilovers, but need to explore them a bit more. Kinda rare when it comes to the Mustang, I'm beginning to see..
It should be noted that the axles on Cobras handle the power just fine (390hp). The SRA with 31 spline axles will grenade just as easily if you go much above 400hp and run D/R's or slicks.
Not to say they are weak, but both are about the same as far as HP they can handle, now the CV Joints on the IRS is another story entirely.
E.
E.
ORIGINAL: crewwolfy
cool i may stick with the sra and get a good set of arm and shocks. i plan to get the sub frame connector regardless of what i do. whats the best set of lower arms to get for a resonalble price. i dont want to cheap out and get garbage but i dont want to spend a morgage payment on them either lol.
I am planning to go with Maximum Motorsport LCAs and Bilstein Struts and Shocks. I know several who are very pleased with that package.
I think the Steeda LCAs are probably pretty good, as well as Stangsuspension's private label brand. There seems to be two significant things you are looking for with new LCAs. First is the basic construction of the piece. Either the steel tube (MM & SS) or boxed (Steeda) are structurally stronger than the flexible stock arms. Second is selecting the bushings you want. They all have better bushings than the stock rubbers but you have to decide HOW stiff you want them to be, based on your driving. I believe that Stangsuspension has some good video clips on their site to explain and other sites have good descriptions as well. Make sure you do your research.
Matt's 95 Stang
10-05-2015 07:16 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
